edodonnell
If you have 2.2 rooted and custom recovery installed, then you can use this rom. It is not signed, so you will have to disable signature verification.
update.zip
If you already have 2.2.1 then you will have to use LGNPST. Read this thread if you are not familiar with the process:
LGNPST Lab 1.2 (Better than my fix)
Download this zip and extract it on your pc.
MS690ZV4-root.zip (coming soon)
Flash the update to your phone following andyo70's instructions, but use MS690ZV_26-root.BIN in place of the TOT file. After the update is finished you will need to copy su and busybox to /data/local/bin/ on your phone and install Superuser.apk. Then reboot and you should be rooted.
2.2.1-system.tar.gz
boot.img
recovery.img
update.zip
2.2.1-system.tar.gz
boot.img
recovery.img
