Help lg optimus t code error 50
So I recently had to do a factory reset...someone tried to hack my email and it ended up confusing my phone. It was working fine til now. It tells me code error 50 when i try to send a text message, now has a weak signal and doesn't even show that I have 3G (no my wifi isn't on). I've pulled out the battery while its on and still having the problem. Should I do another factory reset?
Welcome to AF, allikatluv! Just wanted to give you a heads up, I moved your thread to the LG Optimus T Support and Troubleshooting forum, where hopefully someone knowledgeable about your phone will be able to help. Good luck, and thanks for joining the forums! :ciao:
You're not rooted are you? If so, did you install CWM?
If not rooted,I think you will have to reflash firmware to fix these errors. Sounds like your phone virus left some damage, it could even still be on there if you were rooted.
Turns out my carrier was just being annoying, saying we haven't payed the bills yet so they shut them off until we called them. They tried to charge us for something none of us bought or downloaded. Nice try!
