asadullah
This thread is for discussion on development of the optimus.
So far we have root, custom recovery and stock rom. One thing that people have confirmed is that roms from the sprint version of the optimus work as well (not surprising at all). I've got another way to root which will basically make it possible to root the phones when gingerbread is released. Thing is I need to have diag functions which virgin has pretty much shut down...but I think that flashing a sprint rom will fix that.
Diag mode guide
I'm writing this kinda brief but here goes.
first off I am rooted and have a custom recovery which you need.
plug your phone in and then run the lg usb drivers. If you only get like four drivers reboot your phone while plugged in. You'll get around 9 drivers. I then rebooted my computer. Once that's complete then reboot into recovery. it'll install all the drivers again. This time though it'll show you com 12, com13 and two other coms. I used com 12 but it may be different for you. Open up qpst and then select add new port it won't show you anything until you uncheck: show serial usb/qc diagnostic ports only. Select the port you think it is then click okay. It will add the new port and say surf as the link if not then you selected the wrong port.
Diag mode guide
