Root Lg phone not booting PLEASE HELP
Hi. I have a lg l70 that I purchased about six months ago. It is rooted and I have installed a custom recovery. Today I wanted to boot my phone up but it just vibrated non stop. I had to pull out the battery to make it stop. When I plug the charger in it also starts vibrating. If I plug in the charger without a battery inserted the phone responds with a battery with a question mark. So the screen works and my system is not deleted I guess? I installed a few apps from the internet just before so if may be a virus. How can i fix it? Please help me, I really need it.
Hey,
Try hard reset. Or, try to boot into safe mode if you can. You can check if there is anything malicious that you might have done to the phone.
Hey,
I figured out what caused the problem. Just before I bricked it i used an app called ez unlock that was meant to unlock my bootloader. Is there anyway to fix it? I think it is hard bricked. Please help me
Pull the battery, then replace to make sure phone is powered off entirely.
Then press and hold volume up while at the same time plugging the phone into the PC. Do you get download mode or no?
If no, watch windows device manager when you plug the phone into the pc. Does anything show up when the phone is plugged in?
