Lets me just say, I had all three phones in the last month, trying to upgrade from the old Faithful HTC Droid Incredible 1.
New Current Phone - LG Revolution.
Other smart phones I have owned or currently own-
Palm Centro, BB Storm 1, HTC Dinc1, Iphone 3G(My unlocked GSM world phone), BB Tour, LG Revo
Quick Comparative/Musings
Droid Incredible 2
Pros
World Phone (GSM/CDMA)
More RAM than Inc1 (768M)
Bigger Screen (But more washed out than AMOLED in Inc1)
Super Quadrant Scores (1800-1900)
Front Facing Camera
Cons
Worse Battery Life than Inc1
Locked Bootloader
Screen washed out look
Take Away: Returned phone to VZW, not much of an improvement over the Old Inc1, the increased RAM was nice, but for the money all I was getting was a world phone. Decided to jump into 4G world...
Samsung Droid Charge
Pros
Screen Super AMOLED Plus is beautiful
Battery Life Incredible for a 4G phone- 1-1/2 to 2 days/3G, 1 to 1-1/2 4G.
With usage, games, phone, text, surfing, moderate streaming
4G Speeds using Speakeasy on multiple servers-
Seattle 28M Down/18M Up
San Diego 15M Down/8 Up
4G Hotspot worked better than advertised, getting close to same throughput as the phone itself.
4G/CDMA switch was nice feature, did not have to reboot phone too often.
Very light phone, even with case.
Great Bluetooth 3.0
Decent Speakerphone
Different design form factor, grows on you, even the non-capacitive buttons work well.
Best front facing camera of the 4G lot
Best Rear Camera for distance and outdoors
Screen Shot function nice.
Cons
Glitchy Touch Wiz 3.0, replaced with Launcher Pro, fixed some lag, but still not as snappy as HTC Inc2 or LG Revo
Camera not great on close ups
No LED notification
4G in San Diego... The phone would lock up when going in doors, had to trick it by turning data on and off to get it to re-sync.
328M of RAM and RFS file system cripples what could be a great device, they advertise 512M RAM/512M ROM, but you would need to root, format with Voodoo and make into an EXT4 File system to get better Quadrant benchmarks. I averaged 900-950 on Quadrant.
Phone speaker was very crackly on higher volume (May have been the first Charge I took home)
TONS of BLOATWARE!!!
Base color scheme Brown/Orange, not very aesthetic for a high end phone
Cost $300 a little steep for market and 2 yr contract.
Take Away: I really liked this phone, battery life was amazing for the fact that this was 4G and a large AMOLED screen. I wish it had the larger memory, EXT file system out of the box, I almost rooted the phone and stuck with it, I thought the lagging issue was almost bearable. For $300 I was not willing to risk bricking the phone so I returned it for the LG Revo.
LG Revolution
Very Snappy phone, transitions are quick
Great Benchmarks (1900-2100 Average on Quadrant), I compared all three 4G LTE phones side by side in VZW, the LG blew away the HTC TB
Touch Display is very responsive, reminds me of Iphone, I think LG makes the TFT display for them as well.
Replaced Optimus UI with Launcher Pro, preference more than anything
512 RAM, no lag
3g so far is really fast
Have not gone over to Seattle to try the 4G yet.
Battery life not as good as Charge, but better than HTC TB. I get 1 to 1-1/2 day on 3G in Western Washington.
Open Bootloader is nice, considering the root to remove Bing and Bloatware.
Camera is good indoors and out, front facing camera, really sharp.
LED notification is present, even though you see nothing online or in manual for it.
VoLTE, this is the only phone with simultaneous Voice and data capability on 4G network. Don't really know if this would be a show stopper, but it is worth mentioning.
Square Form Factor, easy to get back off of phone
Supports Wireless Charging (Buy $30 back, $70 Charger)
Fast reboot time
Netflix works great!!!!
Video Playback works great
Speaker is clearer than Charge, not as loud.
Cons
4G/CDMA toggle requires reboot
Battery life better than TB, not as good as Charge. Closer to TB battery life.
TONS of BLOATWARE!!! Bing is imbedded in Browser along with VZW crap, but I use SkyFire and Dolphin, so it is a non-issue. Same with Google maps, Google Voice, etc... Just dumpster Bing off your homescreens or root the phone, freeze the VZW Bloatware/Bing Bloatware/etc.
Take Away: I like LG, they have been putting out good products since they left the old GoldStar monicker behind years ago. I had great success with LG dumbphones in past, figured to give this phone a try. The phone does not lag on most applications, the lag worth mentioning is when adding applications to the home screen. I will stutter an extra 5 seconds... It could be the fact I am using Launcher Pro.
Constant muting on speakerphone, acts like dropped calls, but stayed connected
I am probably going to stick with this phone if 4G works as advertised. Charge runs a close second, I wish they had Gingerbread out of the box... If Charge had Ext4 and more RAM, then it would win hands down. The file system piece is fixable but I do not believe we can re-partition the RAM... Maybe a developer can weigh in here and set me straight.
If I had not given my Droid Incredible to my son, then I may have waited to see if the Samsung Galaxy S II came to VZW with the same specs and 4G LTE radio. Somehow I believe it may not happen because of the size of the 4G radio fitting in the GSII Form Factor. Things to consider, VZW unlimited data is coming to an end soon, that is why I jumped to the 4G phone to get grandfathered for at least two years.
UPDATE:
I returned the LG Revolution and went back to the Samsung Droid Charge. The 4G network was not as fast on the Revo compared to the Charge. The battery dropped from 95% to 35% in 4 hours of light to moderate usage as compared to Charge in a more strenuous usage over 5 Hours, it dropped from 48% to 18%, so I believe the DC is twice the battery life expectancy.
Also, it appears the XDA developers have started cracking this baby, voodoo, ODIN, Heimdall, and ROM goodness is underway. I did not install the ED2 update on my second DC, put on Beautiful Widget, Launcher Pro, Skyfire, and the lag stutter is gone, just stock. There is also a rumor that Gingerbread is a week away for the Droid Charge because it is "Droid" Branded. I was poking the VZW crowd, they would not deny that rumor.
The things that won me over to Droid Charge:
1. Beautiful Super AMOLED Plus screen, easy to see outdoors for photos
2. Great pictures, indoors and out, not so much on real close-ups
3. BATTERY LIFE, twice as good as the HTC TB and LG Revo, IMO
4. Better 3G/4G browsing speeds, quicker page loads, IMO
5. The light feel of this phone and the reports of what the extended battery feels like, intrigues me. According to what I read, the batter and extended cover ad some weight and makes it closer to what a stock TB or LG Revo feels like... See where I am going with that... All the marbles, same weight as stock phone.
6. Dev Support! The work going on over at the XDA forum is well worth looking at.
Don't get me wrong, I really liked the LG Revo, experienced buyers remorse, went back to the Droid Charge. For my life style, battery life, great screen, light phone, and dev support are very important. The LG Revo 4G speeds and 4G hot spot drops were too much for me, marked with sub-par battery life and muting problem were the deal killer, IMO. It may have been that LG Revo phone, as I see a whole lot of happy Revo users.
Ask me questions, I will try to answer them as best I can.
I also posted the same forum thread on Droidforums.net,
Droid Incredible 2
Pros
Front Facing Camera
Cons
Locked Bootloader
Pros
Great Bluetooth 3.0
Decent Speakerphone
Cons
No LED notification
LG Revolution
512 RAM, no lag
Fast reboot time
Cons
UPDATE:
). The reviews and seeing what is important and works for people that share what I need are the reasons I'm in this section in the 1st place. Anyway, best wishes!
