Root LG Spectrum first rom
This is the LG spectrums first rom n maybe it will work for connect 4g.n just some edits it might cause I think the connect n the spectrum are alike
Hello all! Here it is Broken Out Rom for the LG Spectrum!!! It has been fully cleaned out to decrease size and to increase speed. It will continue to be a work in progress! I hope you all enjoy!!!
Quote: What is this? This is a very lightweight rom built both for speed and stability. This rom is based off of the latest LG version of Gingerbread, ZV4. It is fully deodexed, and debloated. Almost all of LG has been replaced and as time goes by, I hope to remove the rest. Swype has also been changed to the newest Beta. A few items have been replaced with AOSP versions to increase speed and decrease size. Also included is the appwidgetpicker to clean that up.
Quote: Changelog v. 1.0 Initial Release Rom: Based Off of ZV4 Gingerbread Deodexed Zipaligned Heavily Debloated Debinged the Browser Custom Boot Animation AOSP Lockscreen Power Menu Mod Accurate Battery Mod Center Clock Mod Cleaned Up Notification Pull Down Changed Low Battery Pop Up to 1% CRT Screen Shut Off Added Launcher Pro Updated all Apps Including Google Play Newest Swype Beta Build.prop Tweaks Init.d Tweaks Loopy Smoothness Tweak Added Sony Bravia Engine Added Beats Audio Libs Made My Own Host File From Several Sources to Block Ads Blocked All CIQ Logs From Verizon and Google (Requires Reboot After Install)
Kernel: Compiled and built from stock source No real changes yet
Quote: Screenshots
Quote: How do I install this? 1.) Download the .zip & make sure 4g is enabled. 2.) Place zip in external sdcard 3.) Back up 4.) WIPE DATA!!! (You do not need to wipe if already on GingerVolt!) 5.) Go to install zip from sdcard 6.) Select BrokenOutSpectrum1.0.zip 7.) Do not wipe data after flashing!!! 8.) Reboot! 9.) To Block CIQ Logs Requires Reboot After Initial Boot
Quote: Technical Info This rom includes edits to several jar files, xml's and build.prop edits. As time goes more will be done.
Quote: Downloads v. 1.0 <download link removed>
Quote: Special Thanks!!! Neph81 for porting over CWM AtomIlluminati for testing coderaz for testing
***DO NOT INSTALL THIS ON LG CONNECT***
First this also installs a kernel that is not designed to work with the Connect
Well Since I had to send my phone back because of overheat I gave this a try and guess what bricked the phone, now my phone is bricked and doesn't boot up no LG Logo even. After Soft brick recovery didnt help me :/.
At least people are safe and know that installing this is a bad idea.
so only flash a rom that is known to be working with the LG Connect and not the Spectrum, even thought they are similar.
Sorry for u bricking your phone but ,I did say with some edit might work
do not install this this is not for this phone and it will brick you here is why
1) at this time there is no kernel source, ergo i know you are lying when you say the kernel is compiled from source.
2) there is no CIQ on metro, period
3) "Newest Swype Beta" last i heard is considered warez on these forums
4) seriously, it is a known bricking zip. REMOVE THE DAMN LINK! stop trying to figur eout what caused it, cuz i promise you if you actually could compile a kernel from source you would realize that the spectrum and the connect have a crapload of kernel changes due to screen changes and hardware differences.
P.S ZV4 isnt the newest, ZV8 is what this phone ships with, ZV9 is the update, just food for thought
Download links redacted from the above posts.
As far as Swype goes, I do believe Shabbypenguin is quite correct--they do not want their app redistributed in any way except directly from their approved distribution channels (Market, their website, etc.).
I do know of devs that have developed ROMs and such for phones they do not actually possess, but in those cases, those devs have beta testers that have agreed ahead of time to test-out said ROMs before making it publicly available.
Perhaps a more strongly-worded, higher-profile, warning up-front in the future is in order for ROMs that are untested or that you would like a beta tester for one (with all due cautions, etc.) before publishing a public link to an un-tested ROM?
Root-related activities and actions imply and assume responsibility from both the developer and the user to take every reasonable precaution so that undesirable results do not occur. These precautions for the consumer include vetting the dev and their prior work, examining the quality and completeness of the products and the instructions, and carefully following the instructions provided.
Caveat emptor.
And as another word of warning...
Walks like a duck, quacks like a duck... yeah. Shoot it like a duck.
Real ROM releases for this phone will look much better, not say "Spectrum", and... many, many other things.
Dont mind but lol and please guys take the k0nane and shabby's advice no offence but it was pretty obviously ridiculous to flash the spectrum's rom for connect. Sorry for your loss and no offense please :-
Lol I knew this could happened but I already had a warranty coming anyhow, the phone was overheating too much , and well I'll have my replacement on Tuesday currently I am using my tablet with groove so I'm still contact,:).
