T toker11 Well-Known Member Feb 10, 2011 #1 so i have jrummys overclocking app and just found the part in the liberty tools where you can overclock.... so my question is whats the difference? what are you guys doing? do you set both or just one?
Steven58 Former Heavyweight Champion of Android Forums Moderator Feb 10, 2011 #2 toker11 said: so i have jrummys overclocking app and just found the part in the liberty tools where you can overclock.... so my question is whats the difference? what are you guys doing? do you set both or just one? Click to expand... Just one. Use the overclock app rather than the rom tool. Personally, I use the quickclock app from the market. It's more thorough, imo.
colchiro Extreme Android User Feb 10, 2011 #3 Steven58 said: use the quickclock app from the market. Click to expand... +1 Press the menu button and choose "help" for info on using it. I find I get better results by increasing the minimum vsel it detects by 3 or 4.
