Removed the flashlight app and now it shuts down without the flash problems. Thanks for the help.Start by removing any flashlight or camera apps that you have installed
Check messaging apps for notification settings that may use the flash
If that doesnt fix it.. Factory reset, if that doesn't fix it you will need to take it in for repair/replacement
Yeah im just wondering is it normal for the flash on my skyrocket to go on and off a couple times when im shutting it down?
Thanks
