Root link2sd after reformatt
tanabe
hello guys (and girls)
im new here.. i got a few questions here:
I rooted my X8 and installed link2sd.. everything works fine but i decided to reformat my phone..
after reformatting, all my apps are gone, does it mean that all the previous installations on the SD card are deleted as well? When i reinstall, it doesnt ask "replace app" so does it mean my old apps are gone after reformat?
BTW how can i view the files on the new partition on my pc? when i plug it in thru usb, it says "insert disk"..
any help? Nobody reformat their phone after using Link2SD / apps2SD? need someone to share their experience..
Hi,
Yes, if you reformate your phone it is expected to re-install all your apps.
It a good idea to use something like Titanium Backup coz it is capable to backup/restore your apps as well.
cheers :)
is there any way to view my 1st partition of my SD on my computer? It only shows my media/ 2nd partition when I use my card reader ..
