Doesn't matter. Link2SD takes out the links and data from the /data/sdext2 partition when uninstalling apps.
Don't want to hijack, but don't want to create a new thread either. Link2SD now offers a paid option now and it has a new extra item being moved with the paid app. Does anyone knows what that is and what it does? Thanks.
Which data? I thought the entire app is being moved with the free version, except for the cache.
So does the plus version leave anything in the internal memory? Also, if you were using the free version and upgraded to the Plus, is there anything additional you have to do?
I've noticed I saved a lot of memory with the free version, however, it still fills up quickly even if I don't install new apps. So I'm wondering if the Plus version helps with this.
