When making a call, the background has the chevy SS "watermark", and not the LiQuID watermark...
after installing watermark I noticed a glitch in the call answer slide. the answer slide is half wat off of the screen
This is probably a silly question but what widget is that in the screenshots that has the time/weather combo like htc?
Droid still hasn't booted up...it's been over an hr since it's been on the charger. Does it usually take this long after it's been out of battery?
I have 1.3 installed, anyone have any issues installing 1.4 over the top without wiping? I'll wipe if I have to, just would prefer not too....
brocja01
It's one of those things...probably better off just biting the bullet now and spend half an hour to set everything back up again.
You may be okay but I haven't tested it like that. Many times you try to save a few minutes and you end up spending more time fixings things that broke along the way.
Every time I take a shortcut...I end up paying for it![]()
Since it's not shown here, I thought I'd post a pic of the gorgeous inverted search app:
Hmmm...Ubrocked is secretly wondering why GirLuvsDroid is looking up Statute..."
Girluvs....that is an kick ass keyboard.....what is it? and how can I get some?
thanks
Mike
thanks eb!
thanks
Mike
Its a themed swype keyboard. there is a thread in here somewhere that has a link to the themes for swype keyboard, just search themed swype, should pull up some results.
Just found the link http://androidforums.com/motorola-droid/120932-swype-themes-different-color-faceplate.html
just an fyi - When installing, I made a mistake and installed the rom, theme, and kernel back to back BEFORE initial boot of the ROM, working great though - when I realized what I did, i figured I would use that as a test for liquid and report what happened.
