Well see i kinda already had a paid open home that i purchased way before i rooted so i rather just have it back on there
Having a little problem with fb, I can't get it to dl off of the market, did this not come in the rom?
I can appreciate not wanting to go away from an app you have purchased...but Launcher Pro has been the fastest and smoothest home screen replacement I have used...by a long shot! ADW is not too shabby either
I remember having dxTop back in the day LOL...haven't tried the newer versions...might give that a whirl sometime just to see how it's progressed (if it's still updated).
Script to remove FB is still there - about to install now so I'll let you know.
EDIT: Any picture for the LP dock skin? I'm curious to how that looks.
Has anyone else had issues running this ROM? I have tried flashing to this ROM 4 times now. Each time was from a fresh 2.1 or 2.2 image -- had to try it both ways to be sure -- and after the install, the phone always ends up in a perpetual boot loop.
I got curious and compared the MD5 from the posted text file with the one from my download and they aren't even close. I've deleted the zip and downloaded it three more times and every time I run md5sum on the file it always comes back 2558ea8999955e75aecdfee38ed3a111, which isn't even close to the one listed in the file. What the duece is going on? Am I just being stupid and missing something here?
Please keep in mind that while this isn't my first venture into rooting, this is my first venture into a custom ROM. So, I may very well be doing something incorrectly.
For reference, here's the steps I've done:
1: Via RSDLite, installed original VZW 2.0.1 recovery image
2: Loaded 2.1 update to SDCard and run update via accepted method -- power + x, vol rocker + cam buttons, install /sdcard/update.zip, etc.
3: Installed 2.2 update with same method as step 2
4: Rooted via RSDLite + SPRecovery_ESE81.sbf -- I did a md5sum on the SBF and it is correct.
5: Post rooting, loaded the 1.5 ROM to SDCard as update.zip, rebooted into rooted BL, allowed and then installed the update.zip from SDCard.
6: Reboot phone and then end up in perpetual boot loop
ARG!!!!
What's the difference between the Slayher 1.5 and 1.6 version kernels? I had been using version 1.6, but this rom comes with 1.5?
Not sure which which one I should be using?
PS, How do I check to see if compcache is enabled and running? I seem to remember "/system/bin/compcache stats" (After an SU) but that returns "stats: Not a typewriter" Lol...
For what its worth, I literally installed 15min ago.. and used the Slayher kernels linked in the first post (I installed the 1.2Ghz LV Kernel). Just checked the 'Info' screen in SetCPU and CompCache appears to be enabled as my SwapCache value is not zero..
