Root Little issue with Tazz 1.0
Jazza09
So i've heard a lot about it, so i decided to flash it and it wont let me press the android after it's been loaded. The android will flash white on screen, but wont let me proceed with setting up the phone. I wiped and flashed again, and it's doing the same thing. Anyone know the cause of this?
So to get me through today i re-flashed Froyo v30 and its running slow as hell, the browser moves incredibly slow and the menus are laggy too...i've flashed it before and had a great experience so i was just wondering if anybody knew what was going on
try skipping the setup.
use the four corners trick
first press the top left corner, then top right, then bottom right, then bottom left
it will skip all the BS and cut straight to the homescreen. you will just have to sign into your google account manually
Didn't work, oh well...back to froyov30 i go
you did it wrong then. it works on any rom and any phone.
also try picking change language and then backing out and pressing the android again. im pretty familiar with this issue, it was one i kept running into on WW back in the beginning
Did you flash the Gapps? Had that same problem when I first flashed Tazz. If you don't flash the Google Apps, you can't get past that screen. Just recover, dl the gapps.zip (it's down under the Tazz V7 description at XDA). Then nand backup, wipe/wipe, flash ROM, flash 'gapps-FRF91-desirec-signed2', reboot... And voila!
I'm not sure if this is the problem, but this should be noted for all - you really need to read the developer's instructions closely before you flash. From the xda-developer's thread for this ROM:
DO A FULL WIPE ,, YOU NEED TO RE FLASH GOOGLE APPS, NO THE ROM DOES NOT SUPPORT FLASH ,,NO MARKET WILL NOT BE ON ROM WITHOUT FLASHING APPS
FOR BEST RESULTS, FLASH ROM, THEN APPS , REBOOT ,WAIT A SEC OR TWO
FOR 3G TO CONNECT
IF U GET STUCK AT THE ANDROID SCREEN ,,YOU DID NOT READ,, YOU ONLY WILL GET STUCK AT THE SCREEN IF U DID NOT FLASH GOOGLE APPS LIKE YOU HAVE BEEN TOLD OVER AND OVER !!!
If you flashed from a complete wipe, the first install is slow if you have ever had a Cyanogen ROM before. Cyanogen ROMs can back up your settings and market links online, and on first flash will redo your settings and start installing all of your apps as the phone first syncs. If you have a lot of apps, it can take a long time, and, of course, will slow everything else down as it works.
Yeah, I about threw my phone against the wall when that happened. At least I was able to restore and move the Google Apps zip to the root of the sd where it was supposed to be.
And yes, the reflash of Cyanogen is a bit of a slow process, but worth it in my mind. I love me some Tazz 1.0...
