S SquirrelNuts Well-Known Member Mar 11, 2012 #1 If I'm using a custom lock screen, can I delete the stock lock screen? Is it an apk?
JayBondzeWell Android Enthusiast Mar 11, 2012 #2 no you cant. its not an apk. its png images in your sys framework
Fuzzy13 Extreme Android User Mar 11, 2012 #3 JayBondzeWell said: no you cant. its not an apk. its png images in your sys framework Click to expand... So if I wanted to change my lockscreen could I do it by replacing files in framework?
JayBondzeWell Android Enthusiast Mar 11, 2012 #4 the png images in it. yes. thats how the themers changed from the stop to tap lock
S SquirrelNuts Well-Known Member Mar 11, 2012 #6 JayBondzeWell said: the png images in it. yes. thats how the themers changed from the stop to tap lock Click to expand... Hmm. More effort but still doable. Thanks man.
