Help Lock screen quirk?
D
Deleted User
Guest
Is anyone else's Epic cutting off the date on the lock screen? This is what mine looks like. Not a big deal, just wondering if it is just my phone....
I've noticed that the main screen, the screen that has the lock pad that slides up is missing the date. It has the day of the week and the month, but the date is missing. I can barely see the numbers at the top but it has been cut off. I called Sprint they refreshed it and they were unable to fix it. I now have to take it to a store. I'm wondering if anyone has any pointers, its driving me crazy!
Thanks in advance!
OMG, my phone is doing the EXACT same thing! I noticed it this morning. Its driving me nuts. I called Sprint, did a refresh, that didn't help. So glad to see I'm not the only one!
On my Samsung Epic 4G when I press the power button to lock the screen and then press it again to try unlocking it shows the time on the right and trys showng the date on the left and it cuts it off half way of the shaded box for that stuff
How do I fix the date from cutting off??
Help!
I got the same issue...I wish I would've seen this thread before I did a factory reset. but oh well.
I'm gonna try and flash back to the previous update and see if that fixes the issue. Hell, I don't even know when this issue actually started until a dew minutes ago.
If you noticed, it's just because it started the month of May. I guess it's normally set to cut off or abbreviate accordingly, but if you turn off automatic under network time and manually change the date and go to april or june, it displays properly again. Go back to May and it's funky lol.
I guess I will just live with it until June ;-) If you change the lock screen to use a pattern, it does show the date properly.
I'm so glad I read this thread. Now I know that its not just my phone. I called Sprint back and asked them if I still needed to take the phone into a local store this week regarding this issue. The rep placed me on hold for a few minutes and told me this has been a problem and they are working on a way to fix the issue. She told me that it should be fixed within 24 hours.
I wouldn't hold my breath.
Agreed.
I find it odd that this happened. You would think with all of the "bug fixing" Sprint and Sammy did with 2.2 they would have noticed that May is messed up on the lock screen. My GPS works so I am happy ;)
The date that is on the locked screen is skewed. Its the screen with the lock icon and the date and time. Mine is like..
THU
MAY.
05
The 05 is cut off though..
The root cause of this bug is pretty obvious: The text of the dates such as "May. 04" when rendered in this font is slightly too long to fit in the window allotted by the display, so the interface tries to wrap it. "Mar. 04" fits, but "May. 04" doesn't because of character spacing.
This is aggravated by the inclusion of the dot (period) character, which is superfluous because May is not even an abbreviation. Actually, the dot should probably be omitted for any abbreviated months, such as "Apr" or "Sep" anyway for cleaner style. Just making that tweak, or increasing the size of the window control slightly, would probably fix this -- at least in English locales.
Since "May" is the longest month, the occurrence of this bug will likely go away at the end of this month. Hopefully it will be fixed before May 2012.
Can we make bets that Sprint or Sammy will not fix this super simple problem this month... or before May 2012...
