Blyss
So as most of you know I'm on alliance 3.1 but what you don't know is that my lock screen has been messed up for two days.
You know normally it comes on with the little round buttons that you draw your pattern on. And as you draw the little lines follow you around. And then you lift your finger and it turns red if you're wrong and green if you're right.
Well mine only shows the initial buttons. You can draw all over it and it shows nothing till you lift your finger. If you are wrong it briefly flashes the whole pattern your drew in red.
If you are right then the whole lock screen goes away. That is to say it's functional but not showing the pattern as you draw it.
Now I've got a good nandroid I can go back to but I'm curious as to what's up. Any ideas to try aside from restoring backup? I wasn't doing anything funny around the time it went haywire. Just rebooted one time and it was like that.
Not related to root issues.
