B BCM Well-Known Member May 8, 2010 #1 Anyone having issues with lock ups or the screen rapidly switching from normal view to helicopter view? The only things that takes care of it for me is pressing the power button twice. Bryan
necosino Android Expert May 8, 2010 #2 What is this "helicopter" view you speak of? Do you mean landscape (on its side)? Try calibrating the G-sensor by going to settings
B BCM Well-Known Member May 8, 2010 #3 necosino said: What is this "helicopter" view you speak of? Do you mean landscape (on its side)? Try calibrating the G-sensor by going to settings Click to expand... Helicopter view is when your on the home screen and you press the home button to see all your screens. When I typically lock up the last apps used box pops up as well. I will have a look at the G-sensor calibration.
