Is it possible to customize the lockscreen with different images and widgets without rooting/hacking the phone?
Thanks!
Also I just have one unrelated question: How do I remove/change/add icons to the bottom? You know how in the bottom there are 4 icons. (phone, contacts, messaging, applications.) How do I change those and can I add more then 4?
Thanks!
