Looking @ Car Mounts
Looking at purchasing a good car mount for my Eris. I want something that's visible so I can see it clearly and not have to hold it to change songs or anything like that. I am looking on ebay and came across this one:
1
Twin Slot Car Charger Cradle Mount For HTC Droid Eris - eBay (item 330467249398 end time Sep-10-10 11:58:33 PDT)
Anybody have any success with any other car mounts?
I purchased this vent mount (iGrip Universal Fit Vent Mount - Android Car Mounts - Android Central Store) and it works pretty well...just one funny thing though, when you squeeze the mount to grip the phone, just don't go too tight--it pushes on the volume controls and can set your phone to vibrate...it was funny at the time...:)
I think most of the mounts are pretty cheasy, plus the cupholder and vent isn't a good spot.(at least on my car) I bought a $3 belt clip on ebay and bend a piece of aluminum to mount it to.
I've been very happy with one of these:
FlexSmart FM Transmitter and Charger Car Mount for MOTOROLA DROID SmartPhones
The features I was looking for that it has:
  • Integrated FM transmitter ("remembers" chosen frequency even when off)
  • Plugs directly in to lighter socket (did not want to have to glue a mount or use a vent clip)
  • Adjustable neck
  • Adjustable device holder (works well with Eris)
  • Ability to charge device
  • USB port (for charging other items like a headset)
  • Reasonable build quality
This particular mount satisfies all of these requirements and has held up well over several months of daily use :)
1
that one looks pretty sweet and reasonably cheap. So it plugs into and is mounted from the cig. lighter. Nice. I never had a need for a car mount until recently when I gave my gps to my daughter so now sometimes I need to use the phone gps. I bought a cheap, under $10, vent mount from walmart. Does ok and is pretty stable but I don't like that it blocks the vent. I might have to look into the one you posted.
A long time ago, I bought a vent mounted cell phone holder from the dollar store. Its worked great for everything from my Ipod to my eris over the years. No need to spend 20$ on a piece of plastic.
  • Adjustable neck
I have that one also. Works great. Picked it up on Amazon for $20
  • Adjustable neck
I would love to have something like this, seeing how I want an FM transmitter for my phone, but all the transmitters I've ever encountered were sub par at best. No matter what station they were set to, I always got static. :(
Right. I would describe The FM transmitter in this unit as adequate, depending on how particular you are. I don't have any other way to "connect" my phone to the car's audio system (no Aux input) so I'm willing to compromise. I was concerned because the antenna in my car is in the rear so I thought the distance from the transmitter to the antenna would be an issue but that does not seem to make a difference.
The overall sound quality is ok but certainly not at the quality level of the CD player. I did notice that when the phone is plugged in to charge, that there is some extra noise/static that can be heard. But if the phone is not plugged in, then the signal is pretty clear.
^^ I finally broke down and bought a new stereo for my truck with an aux in.
150$ for stereo + install, and now my long drives have been changed forever. not too bad considering I've spent 60 or 70 bucks over the last few years on different/more powerful fm transmitters that didn't work.
