Thanks any way
No worries... I could be wrong though... perhaps someone else could advise?
yup! titanium and busybox are user installed apps,so you can delete them with settings/apps/manage apps in the conventional manner. or the uninstall button when viewing them in the play store.As for removing Busybox/Titanium... you should be ok to remove them (may be better to wait for confirmation on that). Word to the wise... I know that HTC have said that they will not be updating the phone any more but, in case they do, be wary of accepting an OTA![]()
if im understanding correctly,you are still on the downgrade software/firmware,wich has the black curved bar that you slide down to unlock,as the silver ring is a sense 3.0 thing,wich you had with the european 3.12.405.1.Only thing she has noticed apart from the bloat gone is the silver ring that you drag up in the sense version it had to the pull up bar but its not the end of the world
(i feel you here- my GF does not accept any kind of change with welcome arms
ok,start by updating all your apps,and backing up your user apps with titanium backup or equivalent,and then make a backup of your current setup in recovery.
-download the RUU from here:Shipped ROMs
- download a recovery. i personally recomend 4ext: PD98IMG_ace_recovery_ext_4.zip
but,if you prefer clockwork,here is a link for that: cwm-5.0.2.7-ace.zip
-download superuser: CWM-SuperSU-v0.96.zip
*make sure your phone is fully charged
sorry,but this method is going to wipe your data,youll have to resetup afterwards.
-the RUU is a .exe file,simply disable all programs capable of comuicating with the phone(htc sync,pda net,easy tether,etc),and then run the .exe as administrator,if your version of windows permits that.
-follow the onscreen directions and plug the phone in when instructed. it should update all partitions to newest firmware and software. when its done it will reboot.
-after reboot,you can skip all the start up stuff if you want. enable usb storage and put the recovery file onto the root of the sd,and rename it to PD98IMG. take this oportunity to double check the sd card format(right click,the properties) and make sure it is FAT32. just plain FAT,or anything else,and you will need to reformat to FAT32.
-boot to hboot,by either removing the battery for a few seconds,or uncheck the "fastboot" setting in settings/power,then turn the phone off. from a powered off state,hold vol down/power to get to hboot. hboot should find the file,check it,and then ask you to update. after the update,press power to reboot.
-enable usb storage once again,remove PD98IMG from your sd,as it will prevent you from entering recovery. place superuser on the root of the sd
-boot to hboot again,this time select recovery after the writing flashes. when in your recovery,wipe cache and dalvik,and flash superuser. when its done reboot
*you are now rooted on 100% stock european 3.12.405.1![]()
