Root Looking for Prl 60686
I believe if you are on a Sprint based sense Rom, all you need to do is go under menu / settings / updates and update your PRL. That should give you the latest PRL.
i dont have the prl you are looking for, but I am currently running 11115. from my understanding, this is a Sprint PRL that is for business accounts. It will allow 3G roaming in certain areas, and its Sprint..so you can still use wimax, etc. its available online..if you google. otherwise, from what I understand..just like Granite said..if you are on sense..just update the PRL through the phone!
proplem with that is im rooted and im sure that wld effect my root. but good keep em come!
You don't have to worry about losing root or not having the ability to update your PRL because you are rooted. Just make sure you are on a Sense based ROM. Again, you can update your PRL while rooted w/o issue.
thank you thank you, but im running on the mikg rom. I recently tried PRL: 01120 and 60675 and they didnt work so hot in my area.
KEEP THE POST COMING!! :-)
I'm on mikg 3.11 and was running the Verizon prl. I updated it in the settings and went back to the one you asking about.. It will not harm root. Just update
yup thanks it worked without a problem!! but the service is now one or two bars max...... thats how i no im back on sprint! lol im going to check out other PRLs.
Does a PRL change allows ur phone to roam without your phone even know its roaming? When i was on the 000001 prl or (verizon prl) it never showed i was roaming and the roaming blocks where still on my phone when i was running verizon.
will be checking out the 11115 prl shortly just download it.
thanks
I'm currently using PRL 52515 which I heard is the latest Verizon PRL. It has got to be because my speeds at my girls house are plain illegal. Once flashing this PRL I was able to get more manageable speeds. Outside my front door on this PRL I'm able to grab 2 bars of WIMAX.
Would prl 11115 work any better than my 61086 prl? Or does different prl's work better in some areas than others?
right one prl might work really well at the office but not at home or vice versa. All the prl really does it choose what cell tower to connect to first
nice thats wat i like to hear!! verizon speed with sprint unlimited!! good post ill look for that plr
** UPDATE**
Just to share with all od you, these are the PRL i have tried and how they worked for me. (in order of best to worst)
00001- great
01337- Great
52341- Great**
60681- ok/good
60676- ok/good
60677-ok
01120-ok
31010_mod- ok**
11115​
are those sprint PRLs? I know 00001 is verizon, correct? May want to be careful, as sprint may boot you for roaming too much.
It's a Verizon prl. Supposed to be the latest one I heard. I have 00001 as well. Need to put it in my dropbox just in case someone need it.
thanks ice. are you able to get phone calls? my experience w/ verizon prl, or roaming at least my phone goes straight to VM...
