*Use Astro to save all your apps
*Use MyBackup Pro to save other data (SMS, MMS, bookmarks, dictionary, moreiconswidget, system settings, android home). Do NOT use it to backup your contacts/calendar, those are saved up in the cloud safely in gmail, if you try to restore those then you might get duplicate entries for everything.
*Root & Flash a ROM: once again, this thread is not for explaining that.
*Enter your gmail info into the phone so you can access the market and re-download Astro and MyBackup Pro.
*Reinstall apps (this is the tedious part that takes forever since you have to do them 1 by 1, and you will contemplate suicide)
*Menu->Scenes->Clean Slate. In my experience, if you don't do this then when you try and restore 'home' with mybackup you will get big errors. One time I had a widget that took up parts of 2 homescreens and attempting to remove it would force-close (FC) the phone.
*Use MyBackup Pro to restore data. (NOT CONTACTS OR CALENDAR!)
*MyBackup prompts restart, do so, when it reboots you should see your homescreens more or less like they were.
Looking for a Guide for installing Roms on 2.2, and also making those things called "Nandroids".
Links would be helpful. Thanks :]
