KlexKavark
Every night i go to sleep with the phone at 100% battery and i sleep for 6 hours. When i wake up ive lost 25% battery. Data and Wifi are always off while i sleep. Let me explain my set up. I am running Gingersteem Extreme 1.1 with the Plague 2.2 hdmi fix kernel. I think some of my apps are conflicting with each other but i dont know which ones and how to fix it. The apps i think are conflicting are setcpu, romtoolbox free, romtoolbox pro, LG Esteem Optimizer. I have 2 romtool boxes because GSE comes preinstalled with the free version and i had already bought the paid version but it doesnt overide the free version they sit side by side in my app drawer. Now ive never used the cpu sliders in either of the rom tool boxes. I only used set cpu to oc and set profiles. Here are my profiles:
Main : min 122mhz max 2ghz ondemand
Charging : min 122 mhz max 460 mhz ondemand priority 100
Screen off : min 122 mhz max 460 mhz ondemand priority 90
Additional Information: I cant use 2x battery because it doesnt bring back my 4g when i unlock the phone. Same goes for Juice defender. I just use a widget called Data Switch to turn off 4G. Also in the esteem optimizer the mods i used are the battery sensor delay i have it set to chuck norris mode and memory mod i changed the vm heap size to 48m and i use the boost sd card speeds and disable swap file. And as far as rom tool box pro i only touched the boot screen changer and icon changer nothing else. Can somebody help me please?
I like the thanks button
