Try to launch a widget and it will prompt you to purchase or enter your activation code. Go back thru your old emails and find the one Fed sent you with the code and re-enter it.
I really wish Fede would implement a license to keep on your SD card so you don't have to keep putting your code back in. As much as I flash now, I actually have that thing memorized. lol
If you use the save settings function in Launcher Pro Plus it will keep your code in. That is what I do, after I flash I restore LPP from backup and everything loads back in no issues.
