well, mine is not working this morning. i did try the 'select input method', and selected Swype, but alas, it doesn't work. it worked fine last night.
this is a copy that i got directly from the Swype beta site after signing up several months ago....so, i dunno what to do?
First, I would try rebooting. If that didn't work, I'd install it and reinstall a fresh copy. I hope that helps...
where do i get a fresh copy?
thanks.
and btw...i've never been able to find ShapeWriter (or whatever it's called?) to download it.
is it, or is it not, available for the Eris?
thanks.
Being the only person not invited to the beta...
i meant, no where to get swype anymore?where to obtain slideIT?
oops, never mind. i found it.
My method of getting it to work again is to uninstall Swype from the applications manager, go back to my downloads folder on my sd card, uninstall (but not delete) the Swype Installer that I kept on there from the email they sent me, install it again, put in my email, yada yada... and it will work again.
yep, all of the rest of us emailed the folks at swype and said "don't invite this guy!"![]()
i called verizon and they are telling incredible does NOT have swype - what's the deal?
