Help Low on memory can't access usb
Mkeyboy
39
0
Not sure if this is in the right section. I have the galaxy s2 and I'm a noob I've always had a iPhone.
Had the s2 2 months and it seems to be low on memory. It's a 16gb phone and ihave 1.10gb left of 197gb of system storage, And have used 1.75gb of 11.50gb on the usb storage.
My question is how do I get to use the usb internal memory/put all my apps on the usb memory because there is loads of room left on there.
Thanks
If you don't have an external SD card then you need to include ALL your data in the form of pictures, music, etc that will be on your internal sd card (usb storage). Go to the application manager in settings like i said. slide one screen over until you see "on sd card" and select each app that doesn't already have a check by it, and move that app.
Upvote 0
I don't. It's really annoying. It's like the phone randomly puts apps on the sd card when I download them. And some get put on the phone. I don't get asked where I want to save to either.
I asked a mate about my low memory and the first thing he said was to put all my apps on the sd card, when i to him my problem he told me to sign up here cos he was baffled and he's an android geek lol (doesn't live my way tho)
The phone is on 3 but unlocked. Weather that makes a difference? I didn't buy it new either. Also there's a load of factory apps I can't Uninstall, they just come back upon turn on.
Upvote 0
Well to remove Factory installed apps you have to be rooted, and then use an app like Titanium backup to remove those apps. Factory installed apps (aka bloatware) are installed in a protected part of storage that a normal user can't write to, but a rooted phone can access them and remove bloat apps.
Some apps will by default, not let you move them to the sd card, those are usually apps that have widgets associated with them. There are ways to work around that as well, by using an app such as "Folder Mount", which also requires you root the device.
Upvote 0
Doesnt sound right at all. Id suggest backing up your contacts to your google account and then factory resetting the phone. Especially if you bought it from someone with stuff still on it.... makes no sense. Almost sounds to me like the person that had the phone before you had the phone rooted and made a swap partition in the internal sd. Definitely factory reset at the least. But if it was me id root and format the internal sd in recovery then flash a bloatfree rom
Upvote 0
I have done a factory reset number of times. I also reflashed JB on it few times (been having problems with auto rotate) and still didn't sort it. It may have been rooted cos it was on 3 but unlocked.
Thing is I didn't have any problems till a mate decided to Install Revolt on it to try sort this memory problem out.
Attached 2 pics of my memory
Upvote 0
BEST TECH IN 2023
Smartphones
