"Low on Space" error - Rena3
Hello All,
My tablet is the Rena 3/ Renesas Tablet,
I am just posting, as I currently have a problem with my tablet. I decided to upgrade the firmware, following every instruction clearly on 06/29/2011 - RENA3 - NEW LOW PRICE | Top Notch Tablets , and it was successful. Then after that I rooted the device using z4root. This also worked flawlessly. But after downloading Angry Birds, I was given the "Low on Space" error. So I moved Angry Birds to my Micro SD card, but still the problem persisted.
The firmware version I upgrade to was 0.525.
I then checked the SD Card and Device Storage settings, and they are a great deal lower than they were before I upgraded the firmware. The Internal App Storage Available Space is now only 18.40mb, and the Internal NAND Storage Total and Available Space are both 00.
I then deleted Angry Birds, but the problem still persists.
Before I upgraded the firmware, I had around 170mb free Internal App Storage Available Space, and that was with quite a lot of apps installed.
Thank you to anyone with any suggestions.
It is quite clear that the partitions on your ROM is messed up after you upgrade. You need to reflash the tablet with a compatbile ROM and it may fix the problem.
It is likely that the ROM you got from topnotch is not the correct ROM for your tablet. There are many variations of this tablet around.
