How do i get rid of this
Is there any way to move videos/pictures to the SD card?
The card isn't the problem. It looks like there is plenty of space there. The problem looks to be on the internal memory.
thanks, that makes sense.
Sorry, I'm not very "techie" and this is my first android, so i'm troubleshooting as I go.
Did you all say that all photos and video that i take are stored on the SD?
Everyones response is correct here. I received the low on space message in my notification bar about 3 weeks ago. I did a hard reset and started over. I had too many apps installed. I still have a lot but I have at least 215MB of Internal Phone Storage. So I guess thats not so bad. Don't download apps you will not use.I continue to get a Low on Space Notification and am unable to download apps.
How do i get rid of this and how do I move items stored on the phone to the SD card. It appears that I have a lot of space available there.
When you back-up within ASTRO to your SD card, can you install those apps from the SD card, to the SD card? Thus, saving space? Also, will they show up in the market's downloads section for updates?Yes, they're in a folder called DCIM/100MEDIA on the sdcard.
As a basic user, you will _not_ be able to do things to the phone's internal memory other than to basically install or uninstall apps.
If you haven't already done so, you want to get the ASTRO File Manager free in the Market - there are other file managers, they're great too, but start with ASTRO - you can use it to familiarize yourself with your card's layout.
With ASTRO - you can use to freely backup your installed apps to the SD card. It sounds like you've started to hoard apps - so back 'em up using ASTRO and then do as others are telling you -
1. If you are running 2.2, you go (from your phone desktop) to Menu -> Settings -> Applications -> All (tab), you can click on each app you've installed and if the developer allowed for it, you tap a button to move the app to the sd card.
2. Start deleting apps that seemed like a good idea at the time - don't worry about what if you need it again and what if you can't find it again in the Market - ASTRO's backup will let you re-install any, all or onesie-twosie.
If you're unsure if you're running 2.2, you find that out under Menu -> Settings -> About phone -> Software information
PS - Welcome to the forum!
I have been receiving the "low storage space" message for a while now, and have made it go away by moving apps to the SD, and clearing data on some apps, especially the default internet app.
However, Gmail has continued to top my list of space hogs, taking 50 mbs, then 60....a couple of days ago, it shot up to 110 mbs. I have no idea how that happened. I have gone online to delete hundreds of emails, but Gmail is still using 110 mbs on my phone.
So my question is, has anyone here used the "clear data" option w/Gmail on their Evo? I just want to be sure before doing that, that it will not will not delete data from Google's servers.
Thanks!
I have seen this many times with the space issue...it is an issue with some Evo's, even the Evo shift that I have seen.I have been struggling with this problem almost since I fist got my EVO 4G (original) and have yet to find a workable permanent solution leading me to believe this is a system design flaw.
There is no good reason a user should have to limit the number of apps they download (within reason) or spend as much time as I've spent managing their system/device. This was never a problem with my Palm Pre nor have I seen or heard GSII or III owners complain of the same problem so I don't believe it's an Android specific problem, it must be HTC and/or this particular product.
My next move to solve this problem, until I'm upgrade eligible, will rooting so I can move everything to the SD card. We'll see (crossed fingers) if that solves the problem.
Meanwhile I've become (an unfortunate) expert at 'Factory Reset' then reloading the apps I want and need (pain in the butt), still eventually I know I'll be looking at "Low Storage Warning' at some point in the future.
If anyone knows/has a more reasonable/scientific explanation for why this happens and/or a better more permanent solution, other than the ones already suggested here (Astro, App2SD, etc.) please share.
Thanks and wish me luck on my move to Root Village.
Larry
