K karl35 Lurker Sep 17, 2010 #1 my htc wildfire keep saying low phone storage,ive deleted a few apps but message is still there,can someone please hepl cheers
Steven58 Former Heavyweight Champion of Android Forums Moderator Sep 17, 2010 #2 Could be a hardware issue. However, I'll forward this to the Wildfire section for you. Welcome!
SUroot Extreme Android User Sep 17, 2010 #3 Menu>settings>applications>manage applications Menu>Sort by size. This should now list all the apps in size order. You can go into them and perhaps delete cache. Be careful not to delete contacts or anything though. This should free up some space.
SUroot Extreme Android User Oct 22, 2010 #5 wtf?! said: can i somehow move fies from phone to SD storage instead delete it? Click to expand... You can move apps to SD card in Android 2.2 Froyo Is it released for Wildfire yet? If not you would need to root the phone and put a custom rom on there which is froyo. Or root the phone, flash S-OFF and increase /data partition. Both risky (first option less so) but neither are for newbies or the non-tech savvy.
O ocel0t Lurker Dec 24, 2010 #6 With froyo 2.2 out, you can move apps to sd card under the manage applications menu
