just try it out... i use the undervolt and overclocked kernel and it is actually better to me
I first tried the undervolt/overclock+N and noticed a pretty big drop in life.
I just started using the undervolt+N (stock clock) and battery life seems largely improved. Only seeing about 1-1.5% drop an hour as phone is in idle on a 1500mah battery.
Anybody have any ideas on how to verify that the WiFi is running at Wireless-N speeds? I have my AP set up on G/N mixed mode and in the wireless settings page it shows 54Mbps as my speed still even after flashing and validating the kernel is installed.
activate N only on your wireless router through its menu and see if your phone connects... thats how i figured it out.. also when you look in your wifi menu on your phone and click on your network it should say speed of 65mbps or higher not 54 since thats G
My incredible connects to my Airport Extreme as:
b/g/n with a rate of 65
My laptop connects with:
b/g with a rate of 54
I named my 5 Ghz network differently and neither device can see it. I assume this is because neither device supports 5 Ghz (cheap wifi card in laptop).
Maybe the incredible only supports 2.4ghz?
I have the uv kernel right now and it works great. If I want to go back to stock kernel, or change to of, do I need to do a full nand restore or advanced restore and boot restore?
What are the downsides to a low voltage kernel? Why don't all phones run on "low voltage"?
I'm the undervolt kernel, the oc/uv put me in a boot loop so i thought i'd try the uv. i put in my new 1500 oem battery yesterday and loaded this kernel. i've been off the charger for about 2 hrs now this morning and i'm at 98% still although i've barely used my phone today.
So I tried out the oc/uv and got stuck in rebooting. When I did a boot restore, I lost WiFi. It said it was unavailable. I had to reload the uv kernel that I previously had. Any idea why it lost WiFi? How do I get it back if I want to go back to stock?
Can't hurt to try...giving the new UV + N a try, will report back.
2.6.29-Hydra-uv-n-v02
Anyone else noticing severe keyboard lag?
I have the keyboard lag whenever I try to do the fast reply in this forum.
