sanity29
Im not sure if its a blown speaker (no crackling or signs of blown), or a setting that got turned on or off. But during calls the volume is very low compared to a few weeks ago. It was just sudden. No matter what i have the sound turned up to its just low sound from the earpiece.
I running mikg 3.11 and underworld 07 sbc. Are the any setting to check in mikg? Should i try reflashing the ROM? Or just take it in to have the speaker replaced? I do have voice privacy on if that does anything.
I only ask because it just happened suddenly.
