Root Lunar-Gen [Final] (Admire Oxygen) [Inspired by oxygen rom]
genovdot
Android Expert
First and for most, I want to thank Requisite0 for letting me use his stock ++ build, cwm and kernel. This is what i like to call a SUPER-STRIPPED rom. Its based off of The oxygen rom for the nexus s 4g, htc desire, nexus one and sgsII. Its the final build, (finally) I got a wee bit couple more things to do but its as small as theming changes. I gotta thank paris to for helping me out with some of this.
For wallpaper pack just extract the files to your sd
Let the phone sit for a while for the market to work also. This is a problem with the play store, not the rom
Change-log
V 3
Added V6 Supercharger tweak to build prop (this thing flies!!!!!)
Paris hooked up some visuals
stable as s**t!!!!
got a few more things to still do, very small though
sorry i couldnt do more with the admire, i gotta focus on the attain now
oh yea, added a wallpaper zip and an Easter Egg :D (constantly tap android version in about phone)
V2.5
75% Of the rom themed by me this time
added init.d tweaks for performance and data (thanks mystery)
Replaced zeam with LauncherPro
Updated Market
oc'd to 900mghz (as is previous build. thanks req!)
added dsp manager
added file manager
90% of apps zipaligned (I missed a few)
Changed font (looks much more clean)
Working on boot animation (its giving me a major headache)
added build prop tweaks
added poweron.wav for boot up sound
changed default wallpaper
changed unknown artist icon in music player
Still in the process of adding things. Please hold tight for the goodies!
and finally, changed the name to Lunar-Gen. (LunarUI themed mixed with Oxygen Rom)
V/1
Super-stripped the rom of all bloat! (thats my new term. lol)
replaced stock launcher with zeam
did very small theming
changed boot ani qmg (2.3.6 boot ani qmg)
changed shut down ani
added transparent notification pulldown
already set oc'd to 900mghz! (Thanks for the oc kernel req!)
Side Note
Phone runs very smooth when the display settings are set to NO ANIMATIONS.
YOU WILL NEED REQ'S CLOCKWORKMOD AND KERNEL TO INSTALL THIS ROM!!!! WILL BE POSTING LINK AS SOON AS I GET FREE.
IF YOU DONT KNOW HOW TO INSTALL A ROM YET YOU SHOULDNT BE IN THESE THREADS. WIPE WIPE WIPE!
And finally the rom.
Download
Final
Lunar-Gen.zip - 4shared.com - online file sharing and storage - download
Wallpaper Pack
Lunar-Pack.zip - 4shared.com - online file sharing and storage - download
Beta-2
lunar beta-2.zip - 4shared.com - online file sharing and storage - download
Beta-1
Oxygen Beta-1.zip - 4shared.com - online file sharing and storage - download
In your opinion Geno which will be be better once oxygen is stable. Monster or Oxygen?
More than like oxygen. Its gonna be based off of req's stock ++ build and its gonna have a lot less stuff to worry about. The beta's are just something to play with until I get all the tweaks up and running.
Just be careful messing with the updater-script, and you should be fine.
Um OK everything works fine, loving the launcher. What feedback do i need to give?
Anyways, i'd say to integrate Kick Ass Kernelizer and V6SuperCharger,Smurfed Out Script, and especially Zv6 tweaks.(Since init.d tweaks work!)
So far , its looking good.
Going through the rom.. 'Battery Use' doesn't work when connected to Charger(stays at 44sec, when i disconnect the timer works, but when i connect it to the charger, it stops counting)bIs that part of it or...?
Anyways, all apps are working fine!
Thanks. Ill check that battery problem out in a sec. Got chores to do. Lol. Ill add the tweaks into the next beta
Thank you, this is exactly what I was looking for. a debloated stock++ rom :D
But one quick question: Will wiping, flashing, formatting often damage my phone somehow?
Reflash, wipe data, cache and dalvik of course, go to mounts and storage afterwards, format the data, and system. Then reinstall the zip. See if it works then
