stewie1350
Member
im tryin to find the board.sholes.c to overclock the admire but its not in here if anybody can tell me if its a different file
the file that would need edited is the acpuclock.cThank u playfulgod![]()
You making a kernel
Yes im goin to test if at least i can get the admire to 910 to 920 lets see what happens![]()
Lol i wish you the best of luck my friend ... But did you know that req0 got it at 1ghz stable (thats a little motivation so you can push the phone to its limits)
Yea and the battery blew up he's lucky he didnt get burned
stable, prolly not w/i undervolting the pi55 out of it and then it wont have no better performance than it does @900Mhz.So its possible to get the admire running at 920 mh??
this is what i did
/* 7x27 normal with CDMA-only modem - PLL0 and PLL1 swapped and pll2 @ 800 */
static struct clkctl_acpu_speed pll0_960_pll1_196_pll2_800[] = {
{ 0, 19200, ACPU_PLL_TCXO, 0, 0, 19200, 0, 0, 24576 },
{ 1, 98304, ACPU_PLL_1, 1, 1, 98304, 0, 3, 49152 },
{ 0, 120000, ACPU_PLL_0, 4, 7, 60000, 1, 3, 49152 },
{ 1, 196608, ACPU_PLL_1, 1, 0, 65536, 2, 4, 98304 },
{ 0, 200000, ACPU_PLL_2, 2, 3, 66667, 2, 4, 98304 },
{ 1, 320000, ACPU_PLL_0, 4, 2, 160000, 1, 5, 120000 },
{ 0, 400000, ACPU_PLL_2, 2, 1, 133333, 2, 5, 120000 },
{ 1, 480000, ACPU_PLL_0, 4, 1, 160000, 2, 6, 120000 },
{ 1, 800000, ACPU_PLL_2, 2, 0, 200000, 3, 7, 120000 },
{ 1, 850000, ACPU_PLL_0, 2, 1, 200000, 3, 8, 120000 },
{ 1, 900000, ACPU_PLL_2, 2, 2, 200000, 3, 9, 120000 },
{ 1, 910000, ACPU_PLL_0, 2, 3, 200000, 4, 0, 120000 },
{ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, {0, 0, 0}, {0, 0, 0} }
THE TOP ONE IS WRONG ^^^^^^^^^^^^^^
THIS IS THE RIGHT ONE
/* 7x27 normal with CDMA-only modem - PLL0 and PLL1 swapped */
static struct clkctl_acpu_speed pll0_960_pll1_196_pll2_1200[] = {
{ 0, 200000, ACPU_PLL_2, 2, 5, 66667, 2, 4, 98304 },
{ 0, 400000, ACPU_PLL_2, 2, 2, 133333, 2, 5, 120000 },
{ 1, 600000, ACPU_PLL_2, 2, 1, 200000, 2, 7, 120000 },
#ifdef CONFIG_MSM7X27_OVERCLOCK
{ 1, 800000, ACPU_PLL_0, 4, 0, 200000, 3, 7, 122880 },
{ 1, 852000, ACPU_PLL_0, 4, 0, 213000, 3, 7, 122880 },
{ 1, 880000, ACPU_PLL_0, 4, 0, 220000, 3, 7, 122880 },
{ 1, 900000, ACPU_PLL_0, 4, 0, 225000, 3, 7, 122880 },
{ 1, 910000, ACPU_PLL_0, 4, 0, 228000, 3, 7, 122880 },
#endif
the bold #'s, but like I said all you're going to accomplish is a faster cpufreq # and no performance gains.Where can i find the pi55
