Root Maderstcok md5
magic1
Anyone have any advice on this? I've downloaded the zip off roOolers. Guide but the md5 isn't matching what he shows. Just want to be sure I don't have a botched download before trying it out.
Check the source download site. I am pretty sure Mader gives the md5 in his OP. If not it is in one of the first few posts.
Yeah it looks like the Maderstcok part of roOolers post is a carbon copy of the one on madershram's site. The two mirror links don't provide complete downloads and the last one does but when I open it in astro file manager to view the details it gives me a different md5 than the one in the post. I've downloaded the zip. three times and every time the md5 was the same.
Are you using the stock browser? If so, try using a different one (Opera Mini is what I use)...
Fifth times the charm? :eek: ;)
Here's what I posted last week on another thread re. this (http://androidforums.com/droid-x-all-things-root/306764-maderstock-file-size.html):
My version on my phone is 298,481,300 with an MD5 checksum of: ce7122280eafad4a39ba7fefeb764bf5
Cheers!
edit: also found, in this thread, Maderstcok SBF .zip File U D G, this:
Size: 284.7 MB (298481300 bytes)
MD5: ce7122280eafad4a39ba7fefeb764bf5
which matches what I calculated too (using AFV).
That was me I still have not got the right numbers tried to download thru opea mini could not get it to download all.
I've used the stock browser, and dolphin hd with no luck. I can't get opera mini to download at all. The md5 is different and the bite size is off just a little. It's been consistently the same. Bite -298, 481,286. Any suggestions? Md5-70839d5713f61f8766ab886f59acf19d, if that helps.
magic1,
I just downloaded this file too from the third download link of this page (Maderstcok SBF .zip File U D G).
The download link, maderstcok - OTA 2.3.340 Stock ROM - Downloads - Android Forum, gave me the same file size and MD5 sum as you reported above (which differs from my the place I originally downloaded it from).
I can only surmise that its actually a different file--but I can't tell you which is the correct one.
Just so I'm not making this harder on myself than it has to be if I have the option to unroot with z4 will it make the phone like it was out of the box? I've added a custom boot logo, call of android animation, and am running apex 1.4. Using dx bootstrap and overclocked as well.
By the way, good to talk to you again scary alien. You helped me out quite a bit back in my eris days! ;)
