Major Flaw with Pattern Lock or How to Brick your Droid
Sorry...? I am sorry. I guess I should of posted proof of my statement being complety true. What I am talking about is talked about in the below links. Also if you click the "Forgot Pattern?" on the moto droid button during the temporary lock out the same will occur.
BUG: Inable to login after "too many pattern attempts" with CORRECT username/password - Google Mobile Help
Issue 3795 - android - Couldn't unlock phone after "too many pattern attempts" - Project Hosting on Google Code
T-Mobile G1 Forum - Too many pattern attempts, now I can't login
I have since found out how to do the Hard Reset that should fix the problem but I am not going to try on my phone.
This is how you do a Hard Reset:
You can hard reset your Motorola Droid phone if you want clear all of the data off of the device and start fresh. Here
Please HELP! ok i just bought this phone about a month ago now after being out on may long weekend and having my last one jacked, my b/f 13 year old was messing with it and now im locked out its going on day 5 since its been locked, its asking me for my e-mail and password on this acer liquid so i do so and its just loading it will NOT let me go back to the pattern lock as to where i know the swipe code so for days its giving me any other option but to punch in my e-mail addy and pass how do you do a reset on the phone that has no keybord? and yes i tryed the e-mail and putting in "null" for password..... i took battery out and the rogers thinger and sd card i pushed the little button under the battery witch only turns off and on the phone, i turned the dam thing on and off for 5 days now and nothing it just sits in a loading screen... does it matter if you turn off the settings for internet? this is all new to me and i dont know what to do with the thing...... im assuming you need the internet on the phone for it to work? as im seeing as a serching thing after putting in my information? please i need a step by step help i did everything i think that needed to be done...
hey guys... hm i think i have a little complicated problem like 5 mins before my dumb friend messed up my pattern i have turned of mobile connection does someone knows how reset the lg optimus tnx in beforehand
You can hard reset your Motorola Droid phone if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons downuntil a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Okay everyone here is a TRUE Challenge, how do you hard Reset a DROID PRO? I tried power on with the x button (keyboard always open as it is the Blackberry killer). HOWEVER:
I just got this phone from a friend who was on Verizon and switched to the iPhone4 (72 y/o attorney). He had me do a factory reset to clear his information, but phone was not ROOTED. Now when I start it up it goes to the activation screen, and I wanna Root it and Flash it. HELP A BROTHER OUT!
I have the Android SDK and when I link it to my PC I get the Moto(something) that runs, but I can't see the root directory. HELP ME (without Bricking) GET IN THIS PHONE'S HEAD!!!!
OKAY UPDATE: I went to YouTube, watched how to Hard Reset a Droid Pro R+M+Power, but that just lets you reset the phone, not get around Activation. So, more YouTube and I found if you tap (starting w/upper left) all four corners, like twice in a row, it bypasses the Activation screen. Then I downloaded z4 root 1.3.0 to my computer, USB it onto the Droid and VOILA I have a rooted Droid Pro, that will only connect to WiFi but cannot text or anything else since no service is connected.
NOW - Who knows how to Flash a Droid Pro to Cricket?
Thanks
