Ok- I have a Droid Incredible with the android 1.22 OS. It's old. I don't know how to update it. My service provider is Cricket.
When I got the phone it came flashed for me. After the hard reset I used ##778 and re-adjusted my information to <mynumber>@mycricket.com
The 3G is working, calls are working, text is working.
Picture messaging never worked.
Before the hard reset I had lost my 3G service, after the hard reset and adjusting my information the 3G is up again.
HOWEVER- the STOCK browser is not working, the android market is not working.
The stock browser force closes every time I try to open it, and the android market gets stuck on "downloading" but never makes any progress. I am logged into google talk.
The browser I have already cleared the cache. It is still force closing.
SO- I thought "Ok, so I'll download a new browser, no problem" I downloaded the operamini.apk on my computer and transferred it to my SD card. However, thanks to the hard reset I lost my apps installer application.
So I thought, ok, I'll download the SDK and manually install the application. I downloaded the SDK and it doesn't recognize my device. Also, when navigating to the sdk folder in command prompt, using "adb device" returns the message [ 'adb' is not recognized as an internal or external command, operable program or batch file. ]
So! I am stuck. I need to install this .apk to get a working browser on my device, OR figure out how to fix the browser.
Note: The hard reset wiped the root that came with the flash. I do not know how to root the phone myself nor do I know if it is necessary for the problems I am experiencing.
Please help me. ;~; my phone right now is just a pretty mess with no functionality. Haaaalp.
