Root Make the Flash player 10.3 work on your finger tips
jas2090
Member
its a simple 3 step guide to get flash player working in any (and i mean it ) ROM
if there's getting the attachements then reply me with your e-mails or ask gautam to mail u (if i fail to reply within 24 hours) as the forum is not allowing me to upload it,and im not having much time to upload it again to this forum so i uploaded it to multiupoad website
steps are simple
1. install the flash player apk
2.done! very quickly,don't read the step just do it first.
ah!now u have done,here the second step is copy the files in lib to data/dat/com.adobe.flashplayer/lib and ste all permissions using root explorer
3. no that u have followed all the steps decently,now open up uc web browser.
now don't argue that why its uc only as opera is not supported and the stock browser will never show you the version untill and unless any application demands it from browser and btw our browser is already equipped with partial flash(i.e. it will use your flash but never let u know,esh-smart browser saves battery),u can test that by opening any flash website.
if u get any error contact me,i m just an e-mail away.
links to attchments are
Multiupload.com - upload your files to multiple file hosting sites! for lib files
Multiupload.com - upload your files to multiple file hosting sites! for apk
:Dhi dude.....plz help....which keyboard is good and occupy less memory.....and also select a particular letter for delete in a word is to difficult in micro a70....any easy cursor move application is there.....in samsung galaxy fit ( froyo) its has easy cursor move....is there means plz give me solution...thanx
sorry peerx i don't get your demands ,but u can try a hand at swype as its also used by samsung in their all phone models
thnks varun,actually i attached those lib files becoz sometimes due to exterme modifications system doesn't allow the apk to copy all those files to lib i.e. only 1 file gets copied so to avoid that i attached them,its good if it works dirctly.enjoy
Ok i done it,it got detected in uc browser but somehow not able to view videos on youtube.destop view of youtube says to update flash to 11 to be able to watch.
Thanx dude
Only installed apk and worked for me
Only pc site of youtube working fine not mobile site(opening players)
dude I and some other made 10.3 to port to armv6 to fullfil the demand on online gaming and not youtube as youtube keeps on updating whenever new flash is relased so its not possible to get the armv6 support for flash 11.0 just after month of its release,we have been able to install 11.0 on lg 500 stock rom but in cm its failng so keep paitence untill we get it there bcz if it ges there then its every where
and moreover use stock browser to play youtube videos,it will do it even without flash as it has inbuilt flash components
and the guy saying that mobile site is not working fine as its opening players then dude let me clear u one thing that when on stock (crct me if am wrong )or pc view the streaming is done via http protocol(correct me if am again wrong) that is we call buffering and in mobile view it gets via rstp protocol which is a optimised streaming channel for the non-flash players ie a nokia mobile with simple player can even play that file
,now don't give an excuse that u never streamed on a nokia mobile via its player
Well jas, one ques if flash really geta installed why doesn't it shows up in whatismyflashplayerversion.com in stock? We all know ucweb and skyfire have flash supported so any version of flash armv6 will work on it but not on stock.
N sd ext problem almost aolved I am building flashable zip for that will update till evening around 7pm
yes gautam is right he made flash 10.2 working on youtube on stock browser some days earlier .. 10.3 and 11 was also as that time.. and youtube does not needed upgrade..
Yes....u can install 10.3 even on my rom but 10.2 is better in performance...!! you can even google it...!!
and working on my new ROM it supports flash till now no restarts i guess link2sd is the prob it corrupts the rom gues...!! varun u face that prob naa can u explain that?
No not at all.
I am on Leandros currently
No when u installed hybridv2 and asevmaxxv2 y it restarted u wrote something inapost i frgot that
Yes.
At that time Asevmaxx used to restart rapidly after use flash player
And in case of hybrid v2 (the wrong zip u uploaded)
The ROM hybrid first starts lagging and then restarts.
I wad not having any prob regarding link2sd as of now.
monu and gautam see i think I made a mistake while writing last comment se after heavy goovling and research it found that tye stock also use stock player for playing youtube videos so no question of which flash player version as its streaming channel which nokia can even play
and I told you that flash is used by the bloody stock all u need is to temper the device kernel to make it tell which version of flash is used by stock, se we devs (consider me the lowest of them)try to benifit mass by our work so to prefer to release apk and not the kernel editing commands that enables stock to tell.
see its just a show off thing to get your browser tell which version of flash is it using
if its performing(which u can chevk by downloading from megaupload where it allows fhe clock to run) then what the hell we have to do with why its not showing, see xevs prefer to get performance not show-off
if I want show-off just tell me we will give u the apk which after installation will give flash version as 12.134.27 and while u tru to play a video it will crash,nos tell what do u want from us.
U rite bud. But what if we do both show off n performance ? That's what I mean ;p
And jas didn't u see that sd ext post of mine no replies /
that clock on megaupload is due to javascript not flash.. it is shown on stock rom too without installing flash player.. and youtube does not play on stock browser or dolphin hd.. without or with this flash player
sir, this is not question of showing off..
See I'm having my final practical today so will get back to you tonight till then please post all your doubts I will answer them all in a go. Thnx for co operation
i do appreciate your efforts but just had a small question :
can any one plz tell me the use of flash on phone ?
i personally cannot figure it out !...
