make your phone superfast
hi to all
if you have rooted your phone best if not then use .img file provided by Ninad chaudhari and do root its actually Russian soft image by fly mobile.
After rooting your phone install following App 1)super user 2) Swapper and make a at least 500 mb file and accept super user access 3) install App Sd speed increase and make cahe file as per soft says......................................................... then your phone will zoommmmmmmmmmmmmmmmm:thrasher::thrasher::thrasher:
Hi,
First of all welcome to the forums ;)
Thanks for sharing the Tip !
But just that ,
Superuser app is already installed when you root your device :)
also, thanks for sharing that your device supports Swap ;)
I read something weird here btw ;) :D
kninad2000 :D
hi to all
Tell full tutorial for how to use swapper pls.. I am unable to do it
hey bro first you have to root your phone after that just go to play store search swapper then you will find an app "Swapper for root" just install and use it... your phone will be then supefast actually that swap file act as a RAM by using your sd card memory
you funny guy I just mentioned it
even the developer of that app mentioned that
why?
to just remind everyone!
wats that chip sd card? I cant get it
Dont think the kernelsupports swap file... checked using FREE after installing and swap shows 000... thank you foryourefforts though.
now I am able to run opera mobile,ucbrowser,default web,camera and somemore app at same time with 500mb swap file
lol just installing the apk doesn't do anything
open the app and tick run as boot and choose fat partition and input 500mb and press save now it will create swapfile but dont allow the screen to get locked while creatingvthe swapfile it takes about 5-7 mins
lol... i have done tried it with different file size as well...i select run it at boot as well... and for your kind information there is a command called "FREE" to know the size of the swap that is running on the system and when i type the same it shows swap as zero... how did u verify that swap up and running on your system? the link you have provided is for version 1.4 and the new version is 1.7 which is free as well...
@sathecs that "free" command is for seperate swap partition "mmcblk0p3" I think so
this is really silly u can easily feel the better multitasking lol
well then it is very silly of "swapper for the root" developer because he says we can verify the swap by using free command. Silly Developer!!!
