scotty85
Extreme Android User
so i was reading on "unrevoked"s root wiki(public:forever [RootWiki]) about packing up your own files to flash in hboot,and it got me to thinking why can we not do something like this for the eris?
the page says this:
How do I create a unsigned zip to flash in HBOOT?
Zip the file that you wish to flash (usually named something like BOOT.IMG, SPLASH1.NB0, RECOVERY.IMG, …
up along with an appropriate android-info.txt into a file named either PB31IMG.ZIP (for Incredible) or PC36IMG.ZIP (for Evo), and place this file on the root of your SD card.
now obviously,we would need to rename the zip "PB00IMG" for the eris to find it. i downloaded the gscript.zip from the rooting for dummies thread and located the "recovery" disc image file.
could we put that in a zip along with the appropriate text file and flash via hboot? if so,what does the text file need to say? ive looked at the text files on the PB31IMG zips i have for my inc,and theres not much to em... does it need to say something specific? or is it just info for the user?
your thots? has it been done? if not its hard to understand why not,unless it for some reason wont work on the eris.
thanks for any info or insight
the page says this:
up along with an appropriate android-info.txt into a file named either PB31IMG.ZIP (for Incredible) or PC36IMG.ZIP (for Evo), and place this file on the root of your SD card.now obviously,we would need to rename the zip "PB00IMG" for the eris to find it. i downloaded the gscript.zip from the rooting for dummies thread and located the "recovery" disc image file.
, I decided to give this a try...
did you change anything it said? without question i was workin up to the track ball optional version! but since you said it assumed that the regular recovery was allready present to get it working,i wasnt sure how easy it would be... take small steps,ya know!
since it is not customary to use clockwork or rom mamager with the eris, i guess it just doesnt get screwed up
