i tap on the app store and says server error {Retry} i dont know wat to do please help thank you![]()
I dont know wat i have done with my phone i cant go to google play and lock screen dont work please help
And you and it cuts down on confusion.
Did you try what I said above?
Is your phone rooted?
its stuck on the lg boot logo and yes its rooted
Okay. What caused it to be stuck? What recent change did you make? Don't say nothing because nothing doesn't cause a boot loop. I can only help you if you tell me specifics.
Also do you have a ROM installed? Or is it just rooted? Did you flash recovery after rooting?
Not trying to be rude its just people will hold out on saying what they did as they dont want to feel embarrassed or whatever. I dont know why they do it.
i also check internal drive and it has almost nothing like i lost everything all i have is android secure folder which is empty most of them are
You installed a ROM from CWM?
yea it said download ROM i checked it out download it and then i believe i erased it and wen i start up it just shows black screen like theres no theme or app or nothing just black
Did you download the ROM from here? You cant download ROMs in CWM. You can in ROM manager. But did you FLASH CWM inside of ROM manager?
thanks for your help but i had figured it out![]()
all i had to do was download StockZVBRom and re install it
So you had recovery installed? Good.
Make a backup always. And install ROMs from here.![]()
