Root Market problem after root
burg1n
I tried searching around but couldn't find someone that has fixed the same problem I'm having.
I rooted with Easy Root
Then used clockwork and installed:
http://androidforums.com/roms-droid/141351-frg22-fastest-froyo-yet-courtesy-mydroidworld.html
Did everything right, wiped everything and followed all other directions, it was very fast and easy.
Everything is working GREAT
but
My market is missing some apps that I was planning on downloading, they don't show up when I search for them but they show up on my GF's 100% stock (unrooted) droid. When I search for them on AppBrain Market they show up, and when i try to go to the market page for them to download them it says It could not be found.
Any solutions to this?
but
The reason is that FRG22 is not official yet so some protected apps dont show up. I think this is actually still a problem on FRG01B as well. It will probably get worked out once all the updates finish rolling out.
ah ok, thanks!
And what are some good settings to use for the SetCPU app? and A good temp to be running at?
ah ok, thanks!
I generally set the highest priorities to
Temp - Clock down to 500-600mhz range when it gets to 45 degrees C
Charging AC/Full - Clock down to 500-600mhz range
Charging USB/Full - Clock down to 500-600mhz range
Screen Off - Clock down to 500-600mhz range
Honestly I dont put a lot of thought into these settings because I have never had much issue and I have a droid that can take a lot in terms of OC. I can run most 1.3ghz kernels.
I also have some lower priority settings to slowly clock down my droid as the battery drops
