Root Market problem
You should note that I am on the deodexed rom.
if you need the odex apk let me know and I will pull them from an odexed rom
because if it does then you need the odex...if it doesn't then you don't....
if it needs the odex and you do not have an odex then the market will not function properly without it
Gapps comes packaged with the odex files. I'm 90% sure. CM at one point was not deodexed (unsure if that's still the case) You could always flash Gapps on an odexed CM without an issue. Seeing as stock is odexed I fail too see a problem.
