Help Mass Storage Mode Disabled on PC
mosdef1
Hi
I have 2 Optimus V phones running 2.2. One stopping giving me the option to go into Mass Storage Mode when I plug it into my pc. It only charges. However when I plug it into my laptop the option to turn on mass storage comes up. Anyone know how I can enable this on PC (assuming it's PC issue)? I assume I must have accidently hit an option to turn removable storage off on the pc somehow.
Is it possible there's a fault with the USB port on the PC?
To my knowledge, there are 4 connectors inside a USB socket, 2 are used for data, the other 2 for charging. Maybe the data connectors are faulty/damaged?
Hey El Presidente. USB port seems fine. I plugged in a friends phone that also has a Optimus V and it went right into Mass Storage Mode. Plugged mine in and it just charges. Can't wrap my brain around this one.
Plug your phone into your PCs USB port, then on your phone go into settings>>applications>>developement>> and check the USB Debugging option. If it is not checked, check it, wait a few seconds, then uncheck it. If it is already checked, uncheck it. Usually when you check or uncheck it, you will be taken to a screen asking if you want to enable USB mass storage, say yes, and a couple of seconds later your PC should recognize your phone as a mass storage device.
If that doesn't fix it, there may be a problem with your phone's usb port, since you already know it's not the PC's USB port malfunctioning. Try a different cable as well.
You might also check your desktop's drivers. You may need to update it's driver base to recognize your phone as a mass storage device.
thanks for the tips. tried change debugging mode on and off and it still only charges with no usb symbol. added drivers same thing. here the crazy part. i plugged the phone up to my husband's linux laptop and it recognized it immediately and I got the Mass Storage option. Tried it again on windows and it still on charges :(
Give this a go ... open up device manager on the windows machine (right click on my computer and select manage and open device manager). Plug in your phone and see if anything changes. What you are looking for is yellow triangles. Remove that device and then unplug your phone and replug it. You might reboot your computer between unplugging and replugging just to make sure there's nothing cached.
