Root Massive problems with clockwork
Hi there I have a massive issue with clockwork recovery (version 2.0.0.7) basically here are the issues
1) wiping battery status doesn't work at all, it just hangs and then restarts
2) when wiping a Rom to but a new one on it doesn't seem to work e.g all the bookmarks remain and WiFi connections
Does anyne have a step by step guide to reinstalling clockwork ( I know how to use adb so have no problem with commands ) so I can fix these problems ???
Many thanks
Many thanks
Your Google account retains a lot of information about yourset up to the re-install process. Are you sure its not Google? Your issues are pretty wierd if their related to 2.5.0.7.
I'm sure as certain parts are being restored even with a supposed "wipe" e.g my wallpaper and alarms and I'm running insertcoin and its randomly shutting itself down.
thats better,
I was concerned you'd flashed an incompatible version of clockwork to the desire
if its 2.5.0.7 there shouldnt be a problem
do you have alpharev s-off or not? if you do then its easy to reflash recovery
if you dont then youll need to re run unrevoked 3.21
are you accessing recovery via rom manager or via voldown+power
thats better,
No its was the one that has been included in unrevoked.
And yes I'm s off
brillian if you are s-off then that makes your life easy
redownload 2.5.0.7 from here
http://mirror.kanged.net/recoveries/recovery-clockwork-2.5.0.7-bravo.img
put in in your android sdk tools folder (c:\android-sdk-windows\tools)
boot to fastboot (hold back and press power)
use the following command in cmd prompt (making sure you are in the tools directory cd c:\android-sdk-windows\tools)
type the following
fastboot flash recovery recovery-clockwork-2.5.0.7-bravo.img
then see if its fixed it
Thanks for the advice above have done the steps and will wait untill the battery is fully charged then wipe battery status from recovery. Thanks for all your help
type the following
Will this work also for the AmonRa recovery 2.0.0 ?
Excellent.
Edit : Ok i tried and failed :\ i posted a screenshot of the cmd below...
Edit 2 : my phone isn't s-off,is that important?
You need s-off, yes.
The only way to change recovery without s-off is unrevoked and that's a bit messy and if you're going to run unrevoked you may aswell s-off
Bugger me >_> ... Is Alpharev s-off any good?
I already tried re-flashing the recovery via 3 diff.versions of unrEvoked,and didnt work...
Ah i see.
Well i just read the Alpharev soff site,to complicated for me ... will stick with the current CWM recovery.
alsoo use amonRA 2.0.1
if you are using the none s-off method you need to be on a sense rom and run unrevoked 3.14
I did try that,but nohtihng happened...it just got stcuk half way through with a msg " waiting for root" :(
I had/have Sense 2.2 rom ... tried with all versions of the app :(
Think im gonna do the s-off via Virtual Box and gonna use fastboot after...
Just one question if u guys know...what happens to my phone after i run the alpharev s-off? do i need to flash a new rom after? or do a nand then wipe and then restore? ...and after the s-off is completed,do i flash the new Rec,right after ?
p.s. i only found AmonRa 2.0.0. can u give the 2.0.1 link?
