beano52
Howdy gang, Here is a windshield mount I fabricated for my EVO.
First I took an old case or back skin that the EVO just clicks into. These are available on EBay new for under $3.00.
Next I took a generic windshild mount (From an old HTC touch diamond)
I took the "phone holder off the windshield mount and used my dremel to cut off the tabs on the end of the mount creating a smooth flat surface. I used the dremel to take off the paint on the back of the case where I would be attaching the windshield mount.
I proceeded to cut the flexible section out of the middle of the windshield mount. I did this at an angle so I could super glue the suction cup end back to the "phone" end. I then glued all 3 pieces together and came up with a really nice mount done on the cheap!
