Read speeds are the most important for use on an android phone. The faster the read speed the quicker the boot up time of the sd card. This is what takes so long when waiting to be able to use your system functions at boot up. The more apps on the SD card, the slower this will be as well.This is write speed, not read speed and is only important for recording video. Read speed is the same of all cards regardless of class speed.
Spending more money for a higher class uSD card for an Android Phone is like throwing your money onto a craps table. You loose more than you win.
If paying more for something that does just as good a job for a particular application as a less expensive item is your thing, I'm sure not going to stop you(must be a peace of mind thing going on). Most of us in this failing economy can only afford what will just get the job done. To imply that someone has to have a more expensive product, just won't do.
Class does not mean Quality.
But I definitely recommend SD Booster. (sorry, SD Booster needs a rooted phone.)Will this card format automatic if i put it in the phone?
Also after formating the card do i drag the old card apps on the new one?
Atmazzz. Do you think you could post screen shot's of the sd card r/w speeds in your Optimus V.
