Help Merge Calls
Huawei Ascend User Manual:
3.3.1 Making a Conference Call
You can set up a conference call with multiple callers.
�� Note:
Contact your network operator to learn whether it supports conference calls and how many
participants you can add.
1. To initiate a conference call, dial the number of the first person to be on the call. While you are
on that call, press , and then touch Add call.
2. Enter the phone number of the person you want to join the conversation and press , or
select someone from your Call log or Contacts. The first call is automatically placed on hold.
3. Once you have connected to the person you have added, press , and then touch Merge
calls to begin the conference call.
4. To add more people, touch Add call and repeat steps 2 and 3.
5. To end the conference call and disconnect everyone, press .
3.3.2 Switching Between Calls
If you receive a new call while you are already on a call, you can switch between the two calls.
1. While you are on two calls, press , and then touch Swap calls.
2. The current call is placed on hold and you are connected to the other call.
Ascend User Manual Download, Click Me!
If this works as a normal land line does (and it appears that way from the manual), you cannot merge calls if you did not initiate the call to a 3rd party. It only works if you have someone on the line and then initiate a 3 way call.
EDIT: the symbols in the PDF don't translate to text, but you probably know which buttons to press for that part.
hello I jst wanted to know how do you manage the conference call like for instance if I was on a conference call with 3 other people and I jst wanted to talk to 2 of them where is the option where I can hang that one person up & I know they have that option because the g1 & mostly all other android phones have that option and I actually seen it on the ascend one time but I dont know how to go back to it
