bethnesbitt
Member
Hey beth, I have 3 merits that I want to get unlock via the method you tried, I remember that to get to the black screen was easy when I first did it but the one I have are seemingly hard to get to make the screen go black, can you post what you did to get to go black? I have tried the same steps I did before but they aren't working, am starting to think that Tracfone may have patched those holes with newer merits.
You said to put the avail card image on the sdcard in the image folder. Shut down then hold home up volume and power. It does a flash to 100% fails and a black screen.
I did it installing avail stock, didn't work with stocknet10. The screen went black, as in, it just powered off. When I rebooted nothing changed. Did get that com port briefly but then it finished booting.
In qpst tools and that unlock proggy from madaco you can get a com port dialing *983*87274 select only diag. But then it goes to 4% says to turn off phone, remove battery hold down volume and reconnect to PC. I tried but it kept restarting after second logo. If you do nothing it tries itself but nothing happens.
I really want to unlock it for my bf. His phone is a cheapo. We live 45 min from Walmart, and CC fees is not worth it.
, one we were able to flash it, it was on a stock avail rom which was not rooted, but we easily got root after following the avail root guides available online.
