Great Man Thnx problem resolved
I found this on Motorola Forums and it worked for me without deleting any contacts.
Good Luck!
"The real problem appears to be that the default "Text Messaging" app does not show you a failed message queue, but will continually try to resend them. The good news is that Handcent shows you this queue and allows you to delete these messages. You do not need to continue to use Handcent, just use it to delete undelivered messages. Make sure to turn off Handcent's notifications if you plan to keep it installed as a deletion utility.
Solution:
1. Install Handcent SMS from Android Marketplace
2. Launch Handcent SMS
3. Press Menu Button >> More + >> Undelivered messages
4. Here you can delete undelivered conversations and end your "messages not sent" woes!"
Solution:
Well i am having the same problem and i went to my carrier and asked them and they wiped my phone sorry but your memory will come backI use the stock messaging system. The phone is unrooted and has nothing added to the sms system. I power cycled it, and pulled the battery, and it is still doing it... I want to avoid wiping the phone.
wipe the phoneHow did you fix it?
The solution still works using the new Handcent SMS app (temporary in my case). Open Options>Settings>Send Message Settings. Scroll down to Delivery Report and select it. Select the tab for Undelivered and then the Trash Can icon to delete any undelivered messages.
I had same problem. Had to install handset SMS for android and force stop my factory message application. Hasn't came up since.I went to txt someone today, and for what ever reason, the message failed to send, and I received the "Message not sent" notification. I tried again, and the message was sent. Now every time I send, or receive a message that notification pops up. "Message not sent - Select to review the message and try again" and when I open the error message, it triggers another to appear. "Undelivered message - Unable to Deliver this message" even though all the txts have been confirmed to go through. This is driving me crazy, any one have any thoughts? It even gives me the message when I open an old txt that I have already read.
You don't have to download a different app. I have Moto G. See my post San(2014) Souchi today 2/16/15. EASY! FAST! IT WORKS!OK guys. I had the same problem on my moto X, and on the moto G. I never had this problem with the and Galaxy or LG phone that I've own before. Bringing my conclusion that this is a Motorola issue. The ONLY way I was able to fix it without wiping the phone to a factory reset was by doing the following. (By the way this only happen on unrooted phone with stock messaging app.)
1.) Download another messaging app (I used handcent)
2.) IMPORTANT, make sure you set it as the primary app for your messaging. Handcent will ask you if you want to set it as primary when you downloaded.
3.) Go into your stock messaging app and disable all notifications.
4.) Go to settings-apps- find your stock app and disable it completely.
One these easy steps are done, you will no longer see that message pop up. I think it's and issue with the stock app. It happen to me 3 times on the moto g and 6 times on the moto X. Never on any other Android phone. Let me know if you have questions.....
Solution:
Thank you so much...this worked perfecty. Went into airplane mode...deleted the whole thread and notifications stopped!!Instead of restarting the phone, try going into airplane mode and back.
