Help Message's blue background changeable?
xiiaoboon
Hi, i'm wondering if the blue background thing behind when i'm texting can be changeable? Because i don't really like the color and i wished to change it but not sure how to..
Yep, whenever im texting someone, theres a blu background behind it.. i wanna changed it to some other color, is it possible ?
if you want to change blue background then try installing diffrent frameworks
mostly htc frame work will work which will give you a black background or you can also try handcent msg or chop msg :):):):):):):)
